if the fuses blew right away then its gotta be a direct short. check with a dmm and see if you get continuity. Follow the wires and youll prolly find a spot where the + is making contact with a ground. Or dont mess with finding the spot and run a whole new wire.
ive never heard of a motor shorting out, but i wouldnt rule out a bad motor. just try easy and cheap stuff first.
