What reader? 94 is not OBDII... A generic OBDII reader is useless on that car.
It's a obd1&2 hybrid with it being a obd1 unit with an OBD2 data logger portWhat reader? 94 is not OBDII... A generic OBDII reader is useless on that car.
Something like that, same mut request plus a few new stuff but with different initialization (non obd2), but McCoy is right, you wouldn't get a response with regular OBD2, you can use the openPort adapter or use a vag type with FTDI chip, grounding pin 1-4 (on the adapter) and it should work with HHH/Mitsulogger/Evoscan.It's a obd1&2 hybrid with it being a obd1 unit with an OBD2 data logger port
You must misunderstand my post. I'm aware I need a specific reader type for my car. Some of the wires were bad and I was going to wire a while new port in.. Well(like a genius)I clipped every wire instead of going one by one (there is 2 of every wire color on the port) and now I need the corresponding diagrams from the pins on the port to match the pins on the ecu before I can even check codes.. 😶Something like that, same mut request plus a few new stuff but with different initialization (non obd2), but McCoy is right, you wouldn't get a response with regular OBD2, you can use the openPort adapter or use a vag type with FTDI chip, grounding pin 1-4 (on the adapter) and it should work with HHH/Mitsulogger/Evoscan.
