1 - 20 of 118 Posts
rock on, yeah rock on
First and foremost, please go to this thread and read at least the first post so you understand this thread that much more.
let's make a collection of Dyno charts from various turbo setups - 3000GT/Stealth International Message Center
As many know, that thread is a great resource for members of this forum, but it hasn’t been updated in some time. I’ve asked for permission, and been given by chris (aka mellon), to take over his project, update it and keep it going. I’m very happy for this to happen. I’ve used his thread numerous times, and I hope others continue to benefit from this project. I will not be changing how the info is presented, or anything like that. My goal is to simply continue from where the last thread was updated, and to keep this project going, using mellon’s original criteria.
I’ve spent many hours looking through the previous thread for all the info that was posted but not updated. I believe I have caught it all and updated it accordingly. All categories have new info in them, except for the 3000 to 6500 rpm acceleration comparison.
Finally, this project relies on you. Please contribute information to this project. It only helps to better the 3S community. The rules/criteria for each category are clearly presented in the first post of the previous thread. Please read them so your data can become a useful part of this project. But please be aware, not all dyno charts are posted to the project. The idea is to show the best that each setup (ie turbo) is capable of producing. Also, I do not have time to take every dyno chart that was ever was or ever will be posted on 3si, and compile it into the project here. Please post your dyno chart to this thread if you would like it included. This goes for the other categories as well. Please post it to this thread for it to be included. It may take me a few days to get it into the project and update everything, but it will be included. If it is not posted to this thread, there is no guarantee of that. So without further ado, the data:
DYNO CHARTS
SPOOL CHART
ACCELERATION CHART
ESTIMATED AWHP CHART
if the images aren't of the latest update, then press shift + your browser's refresh button to force the browser to get the new images instead of using the cached images from your earlier visit.
Discussion Starter #2 (Edited)
Due to the nature of these charts being somewhat crowded, I’d like to be able to supply a link to the post that the dyno’s are originally posted to, so people can see the actual dyno chart. This spot is reserved for that use, for charts that are posted from here on out.
Dyno Charts:
niteryder twin 50 trim BB with race gas
LVA3KGT FWD DR500's @ 17psi, DR III Heads, 8.5:1 pistons
Import Power twin 5027 @ 33 psi, ethenol/meth/93
wsrtt's 9b graph
FastOldGuy 13G graph
LVA3KGT FWD DR500 graph
DR-1000 non-dbb chart (if anyone knows who's car this is, i'll add their name up there)
Norman 3.5L 50 trim (if anyone knows this guys username, i'll put it there. Norman was in the filename of the chart when i downloaded it)
spfan phantoms 21psi
WidowMaker 3.5L 16G 19psi stock heads/cams
97VR4 19T 25psi C16 stock heads/cams
oohnoo 19T 18psi pump gas DRIII heads street cams
Italo Grasso 3.7L Mivec 6765R's stock cams
97VR4 19T 25psi
SnakeSkinner DR750 3.5L Heads/Cams pump+meth
Spool Chart:
Accel Chart:
Estimated AWHP Chart:
SnakeSkinner [email protected] 2920 lbs [email protected] 3.54L
Discussion Starter #3 (Edited)
a new rule is being added. If a chart was posted in a thread somewhere, i would ask if they'd allow me to add it to the thread. most of the time i never got a response, which i took as a silent no. as such, this thread never got updated much. that's changing. in order to try and keep this more up to date, i'll add any chart that i find on the forums here, without needing to ask. the basis for this is that if you're posting it on a public forum, then it's not like you're trying to "keep the cat in the bag" so to speak, so putting it in one other thread isn't going to hurt anything. by posting it in a public forum you're opening it up for discussion/comparison anyway.
Discussion Starter #5
that's fine. if you can provide info for the new setups i'll gladely add them. but just fyi, some setups stay anyway. a good example is trevor's 14B dyno. of course he has moved on to E16G's and gotten better numbers, but the purpose of the chart is to provide info to people on the best that particular setup has made, ie 14B turbos. not to provide info on the most a certain person has ever made with their car.
Discussion Starter #6
is anyone else having issues seeing the pictures loading in the first post? there should be six. or is it just me?
Discussion Starter #8
ok, if you guys can all see them that's fine. i'll figure my issue out later.
Ninja Performance
Very cool, thanks for taking it over.
Thanks for taking over.
good to see it live on, sorry I've gotten too busy with my new business. One suggestion: move the names in the legend so they are in order with the results.
better results = name up top, it makes it easier to find them at a glance.
Discussion Starter #13
thanks for getting this whole ball rolling in the first place!
noted, and corrected. i just spent several hours getting it done yesterday (putting off some other things i probably should have done) to just get the info on there and get the thread started, that i just wanted to get this going, so i posted it without getting every little detail first.
For the Estimated AWHP chart:
Trevor [email protected] 3800lbs 9bs @ 14.9 psi *91*
Trevor [email protected] 3610lbs 15Gs @ 18.5psi
Trevor [email protected] 3600lbs 14bs @ 27.6 psi
Trevor [email protected] 3580lbs E316Gs @ 22.6 psi *91/Meth*
Trevor [email protected] 3572lbs E316Gs @ 30.7 psi
I would remove any of my other entries.
added. your 14B was already on the chart though.
this reminds me to speak to about the spool, awhp estimate, and accel charts. basically, anyone who has contributed anything to them as been added. but they're starting to get crowded, especially the awhp chart. after adding the newer updates, i had to enlarge the chart just so i could get the entire legend on there, otherwise the bottom handful of names would have been cut-off and not visible. this leads me to want to start treating them like the dyno charts, only the best from each setup/turbo would be put on there. but this also seems like it would defeat some of the purpose of the chart. this is a way to get a better feel for what they typical, not always best, performance for a given turbo is capable of. more data points, so to speak. but then there are some (and i hate to pick on you trevor because you do contribute a lot of good info) that have contributed 4 times on the same turbo setup, albeit two on pump and two on race gas, but are they really all necessary? at any rate, i'd really like to hear what you guys think about it. trim the charts, or let everyone stay and be added, or something in between?
also, i'd like to start seperate pump gas only charts. but i'm not sure i have enough info to justify the effort for those right now. if there was more contributed, maybe i could start them.
as always, comments are welcome, and new info to add as well :)
Best of the best.
My opinion is that if you are too stupid to realize that not every car will make that power based on elevation, temps, general health of the motor, etc etc. Then there is no point in wasting space just for you.
Put the best that a particular setup has ever made on the STOCK engine because that gives a bolt on point of view. I feel things like cams, and heads alter the engines output no matter what turbo is on there so they should have their own dyno seperate from the others. For example there should be a stock evo3 dyno/estimates and then a evo 3 with stage 3 heads and cams.
Same turbo but drastic difference in power output. If you didn't do it this way all the setups that have heads, and cams would eventually overrun all the graphs. Worse yet a noob would come along and think they can just bolt on X or Y turbos and make similiar power when the setups on the charts are more than just a stock engine. You could add nitrous to that seperate category aswell because of how it effects turbocharged engines.
Discussion Starter #16
i do try to put significant mods in the legend (such as heads, nitrous), but there is really only so much room. this is one reason i want to start adding a link to the original post with the dyno sheet in the 2nd post. often times the actual mod list is posted along with the sheet.
the main reason keeping me from elminating all but the best of the best on the estimated awhp chart is because that's basically what the dyno charts are. the best of the best. and having a different number from those, and being estimated at that, would be kinda dumb in my opinion.
STOCK ??? HELL NO...!!!
I don't see myself on the chart, so here is my contribution...
This was at 20psi...
Turbo:
Dynamic Racing DR-800 turbo kit
Tail Wastegates
Tial Blow off valve
Alamo Down Pipe
Greddy exhaust
Custom intakes with HKS Air Filters
Engine:
ROSS Pistons
Fidanza Adjustable Cam Gears
Power Enterprise Super Strong Timing Belt
Unorthodux Underdrive pulley
Krank Vent check (PCV) Valve
Polyurethane Motor Mounts
Fuel:
Greddy 720cc Injectors
Steel Braided fuel lines and loop
Supra fuel pump
SX high flow fuel filter
Electronics:
MICROTEC Engine Management System
MSD Ignition Wires
Custom Ground Wires
Greddy Profec B - Boost Controller
Innovate Wideband O2
Greddy Gauges :
EGT
Boost
Fuel Pressure
Greddy Turbo Timer
OPTIMA Red top battery
Here is how it looks like :
Discussion Starter #18 (Edited)
boricua, that's sweet. thanks for contributing, but unfortunately it doesn't best the dr-800 dyno already on the front page. sorry.
was this pump gas? maybe it will be added if i ever make a different pump gas chart.
hey, weren't you the guy testing out the clutchmaster twin disk? how's that going by the way?
edit: also just realized that your chart is in mph instead of rpm. i'm sorry but only charts in rpm will be added. getting exact tire circumference, etc is just too much to ask to get an accurate relation between speed and rpm on each individual's car.
This was on C-16... I know it is not much, it was at 20psi haven't some issues holding boost due to a nasty head lift..!!:(
Anyway, yes I just finish breaking in the clutchmasters twin disc clutch. It just smooth out the lunch from the stop at a red light... now it feels just like stock, but with a serious kick when you do a hi rpm shift. I'm still babying the car, and I think I will have to change the head gasket...:(
More news on that later....:eek:
1 - 20 of 118 Posts
