1 - 6 of 6 Posts
just a guy
I've seen a few people that are running dual DSM intercoolers.
What are the pro/cons of going with these intercoolers? They should be a little larger than our stock ones. Is there a significant improvement? How well do they fit in the stock location? How difficult is it to modify the IC piping to accomodate a DSM intercooler?
I'd love to hear from some people that have gone this route.
thanks
Retired
oh dang! I know someine that doing this but we thought he was gonna be the first :(
no results yet.
The first gen intercoolers are about 1.5 in thicker than the 3/S and second gen DSM. The surface area is slightly larger, but the tubes are bigger inside and the outlets are 2" instead of our 1 3/4". I never got to track test them to see how much of a difference they made, but I do know my oil pressure is 2-3 PSI higher at Idle and water temperature is lower-about 10 degrees when I run the car hard. This tells me they cool the air better.
To make them work they need modified. I had a machine shop relocate the inlets and outlets and weld the moutning brackets from my stock intercoolers. I gave them both sets of I/Cs. The oil cooler must be relocated to the front of the car (see Jeff Lucius's site) for the Driver side to fit. I mounted the passenger side upside down to clear. I was even able to use the stock 3/S plastic ducts.
As for going from 2" I/C pipes to the stock 1 3/4", I used a 1 3/4" O.D. to 1 3/4" I.D exaust adapter I got from Advance Auto. the outside diameter flare fit inside the 2" and the rest went into the 1 3/4".
I did this twice. The first time I had the shop cut off the pipes from my stock intercoolers and weld them to the DSM i/c. this worked, but I wanted to upgrade to larger piping. I'll try to attatch some pics of the first set I had made. This way gave me a tenth in the 1/4 mile and 3-4MPH higher trap speeds. Considering the salvage yard I got the I/Cs from thought they were heater cores, I got them for ten dollars and the shop work cost me $90, I think it was a very cost effective mod.
just a guy
Discussion Starter #4
Those seem like decent performance gains. I'd still be interested to see some pics if you have them.
Thanks.
Can you just get longer pipes and mount the dsm or even our stock ic in the front and make it a "custom" fmic?
1 - 6 of 6 Posts
