1 - 8 of 8 Posts
I can get a picture soon if needed. I bought this turbo planning to do the turbo housing swap. Hobbit has a write-up on this. I'd like $150. It includes the wastegate actuator.
Discussion Starter · #3 ·
The guy I bought it from upgraded to a 14B turbo on his first generation automatic 93 Talon TSi. I was told it has 70,000 miles on it. The turbo itself looks to be in good condition. He said it spooled fine and was in good working order. That's all the information I have on it.
Paul
Discussion Starter · #6 ·
Re: 13G turbo
snake eater said:
Will you take 150 shipped? Is this a direct bolt-on.
I'll do $150 shipped. It is not a direct bolt-on. It is close for the front turbo. You have to swap the exhaust side housings. Hobbit382 did a write-up on doing the swap. The rear is a bit more work. I may keep it if nobody buys it.
Here's the info on the swap. It shouldn't be that hard for someone with some mechanical knowledge: http://www.3si.org/portal/forums/showthread.php?s=&threadid=100066
1 - 8 of 8 Posts
