my cars engine and harness have been removed so i have no power to the seat from the car
ive got my hand under the seat from the back, and can access the bolt closer to the center console with a flat wrench, but none of the rest
ive unclipped 2 of the connectors under the seat, one going to the rear lumbar and a smaller 4 pin connector which im assuming is for the forward rear movement. im also assuming i can attach test leads to the proper wire and adjust the seat right off a battery....
can someone confirm this or have a wiring diagram of the connectors under the seat?
