1 - 3 of 3 Posts
Some of the ebay ones might have extra bungs, not sure. I ended up just getting a bung welded into my testpipe and put my wideband there. Penty of room for the sensor to fit and easy to get everything oriented the way you want if you have swivel flanges on the test pipe (so it doesnt really matter where you weld the bung around the circumference, you just need it in the right spot front to back). You need it after the front and rear precats merge anyways.
It's really no biggie to weld one in. The wideband we are running a special on includes a bung. An exhaust shop can weld it in for $20
1 - 3 of 3 Posts
