21 - 28 of 28 Posts
Senior **i.e. OLD** Member
Very nice install!!!
I forgot to mention that when I did mine that I put my GPS antenna on the very back center of the roof.
It required a good deal of wire manipulation, and the addition of a GPS extension cable, but my GPS signal is instantaneous and super strong...
287637
In my Spyder install, I ran the GPS antenna up the drivers side A pillar to try to help with reception....
Most double DIN units don't "exactly" fit in our opening. In my case I had to "marry" our surround with the one supplied with the unit.
A little bit of super glue, some bondo action and some paint and it came out looking pretty much like stock....
Stereo projects are very fun, wiring can be a bit challenging for some, but in the end, it's the installers taste and patience that makes the difference...
Bob. :)
Thanks, I also had to fiddle a bit with the surround. I modified the mounting brackets so that I could push the stereo a few millimeters deeper inside the dash. That allowed me to place the surround that came with the stereo behind the stock surround giving a cleaner look.
If you're interested, I have an Android 7" double din radio that I was using a few months earlier. Contact me by private messages, so we don't break any forum rules.
I've had 4 different double din NAV radios in my car. I seem to change them every two years, lol.
I did a short review here: New invention, convert OBD1/MUT into Canbus OBD2 for...
My latest one can be seen in this video.
Does this connect to any double din aftermarket stereo system?
You can go to ebay and do a search for "double din android", and you will see a bunch available for cheap.
If you want a little nicer version, you can try the Joying brand.
Robotics Engineer
21 - 28 of 28 Posts
