1 - 5 of 5 Posts
Blingin' Board User
does anyone here know how to remove the dome light enclosure to replace the stocked bulbs?? One of mine's blown out, and I can't quite figure out how to take teh unit off to get to the bulbs. Thank you
More Than Meets the Eye
Pull - it'll come off. Use a flat screwdriver to help.
Yup...right where you see the little slanted tilts on the Dome Cover. I have to replace mine too. Maybe with some whiter lights.
If you use hyper white bulbs for your dome light, it still comes out a little yellow cause of the plastic cover over them. I ended up moving mine to the map lights. They were still pretty bright though.
What kind of bulbs and size's did you guys use??? Im going to try to do that over the weekend. Thanx
1 - 5 of 5 Posts
