1 - 2 of 2 Posts
Lovbyts
I have a new rack & pinion, inner and outer tie rod ends. Shocks look and seem to work great; no leaks. I still have the problem when I go around a curve to the right part way through I get a little extra dip or tug to the right. Any ideal? Tires are new and it did it with the old tires also. I have rotated tires and have new wheel bearings also. I think I will do the lower ball joints next but I'm running out of ideas and it is a little annoying. I have had the car aligned several times and it never makes a diference. I am not talking about fast speed cornering just easy sweeping turns to the right. It does not seem noticeable to the left. Please help.
Ok, Paul, jack up your front wheels (make sure they are up there safely on stands. Now grab hold of the tire (1 hand at 6oclock, the other at 12 o clock). Try to shake the wheel back and forth to check for play in the ball joint. Repeat the test with hands at 3 oclock and 9 oclock.
1 - 2 of 2 Posts
