1 - 13 of 13 Posts
Want Some?
My brother-in-law is a certified mechanic and when checking my plugs, we did a compression test. Here are the results:
Front bank from left to right
221 psi
219 psi
217 psi
Rear bank from left to right
210 psi
219 psi
221 psi
He said my compression was good and holding on all cylinders. Knowing these numbers....What would my compression ratio be? I need to know for some upcoming mods. Thanks!
Aghhhh
As far as I know there's no good way to get compression ratio from a compression test. There may be some formula for it, but I don't know what it is. In any case, your car has 10.0:1 compression unless someone changed the pistons or did some serious headwork.
McStealthless
O.k.
I'm going to be changing the plugs/wires next week and will be checking compression while I'm at it. What is the "normal" range (in PSI) for a DOHC N/A?
Mine was 150-160 on all 6 and the "Mitsubishi Certified Gold Mechanic" :) Said "Ohh yeah thats fine" I dont know I guess thats in Spec for a dohc stealth
Retired
i think the n/a's should be around 200psi
Senior Member
i believe it is ~180psi for the n/a dohc... so that compression is way high...
i just got the manual: @250-400rpm standard value
turbo: 156 psi
dohc: 185 psi
sohc: 171psi
limit: @ 250-400rpm
turbo: 115psi
dohc : 139psi
sohc: 127psi
compression pressure difference limit between cylinders: 14psi
West Side!
If there was a good layer of carbon build up it would increase compression. I know when I took the pistons out of mine there was at least 1/16 to 1/8 in. of carbon build up on the piston crown.
laters,
Gene Crumpler
1992 Stealth ES
Want Some?
Discussion Starter #12
Thanks for the response guys...getting ready to have the heads on my car worked on. When we take it apart, I'll check and see if there is a lot of carbon buildup.
Senior Member
what's up,,, i am from mission actually... lookin to check out the car scene some time soon again...
by the way,,, when i got my car for those glorious 70 some miles after my last overhaul,,, i was able to show off my engine to some chevy and ford fanatics guys i know and they just wet their pants to look at the engine... so damn cool..
all i got is the polished dn y-pipe, polished plenum, and polished valve cover, along with the polished plug cover that says "STEALTH" and the K&N aircharger, plus some cosmetic blue vacuum hoses and the ngk blue wires...
i want the DN Pipe kit,,, but... well let me just get this car to run for a while 1st.... haha...
1 - 13 of 13 Posts
