how do i order this set up?? I have a 93 stealth TT that i would like to use this on...
Order from BlackStealth as he linked above. I would read all my instructional posts as well, just so you are aware that you need more than just the CANBUS device to get all of the data/sensors i have (boost pressure, wideband, oil temp, oil pressure are all sensors you need to add to the car if you want those parameters). Highly recommend this device though.how do i order this set up?? I have a 93 stealth TT that i would like to use this on...
Seconded. The Blackstealth box has inputs for the sensors jrhorne mentioned. Trust me, it's the best mod you can do, hands down. It's like having diagnostics hooked up whenever you drive.Order from BlackStealth as he linked above. I would read all my instructional posts as well, just so you are aware that you need more than just the CANBUS device to get all of the data/sensors i have (boost pressure, wideband, oil temp, oil pressure are all sensors you need to add to the car if you want those parameters). Highly recommend this device though.
Never even thought of that with the knock. Just changed mine.Forgot to post before, but here's a screenshot of my new setup after adding the oil sensors. Note you need to customize each gauge for the min/max values, number of decimal places, display type, display size, etc. I highly recommend the 'graph' style display for knock as it is the only one that shows historical values, so its easy to see if you get any knock during a pull since the instantaneous values don't immediately disappear.
Sorry no it does not. OBD1 is not standardized, it's different between car manufacturers.Does your OBD1 to OBD2 converter work on late 80's GM vehicles? I have a 1988 Camaro that I would like to use Torque Pro with.
Love the layout but I cant find Knock on my Torque pro.Forgot to post before, but here's a screenshot of my new setup after adding the oil sensors. Note you need to customize each gauge for the min/max values, number of decimal places, display type, display size, etc. I highly recommend the 'graph' style display for knock as it is the only one that shows historical values, so its easy to see if you get any knock during a pull since the instantaneous values don't immediately disappear.
Check BlackStealth's main thread or PM him for the user manual, i think the custom PIDs are in there. You need to input/load them into the Torque app. It's been many years since i set it up, but let me know if this isnt enough info to figure it out.Love the layout but I cant find Knock on my Torque pro.
I found this helpful YouTube but still dont see the option for Mitsubishi or did you do a custom somehow?
I think I figured it out, like you said changing the min/max and it my case I had to close the app and re open for it to show up with the new numbers.
I dont have a wideband either so how should I set my O2 monitoring?
Unforunately i cant see my ebay orders from that long ago... it was just a cheap one from ebay. There is a specific chipset that you need. If its not in my earlier posts, BlackStealth will know. I have not tried it with anything besides torque, but i heard it will work with a laptop.@jrhorne which wired USB adapter did you ultimately settle on? And have you used it with a laptop and either HHH or Evoscan in OBD2?
I tried following some of the links but they were all expired.
cheers
poorman
OBDLink LX OBD2 Bluetooth Scanner for Android and WindowsFor USB adapter you're looking for an "ELM327 USB adapter with FTDI chipset". The FTDI chipset is so it works with an android device / and Torque app.
HHH and Evoscan software requires a different cable.
The OBDLink LX is the fastest bluetooth version out there, faster than the ELM327 bluetooth, but more pricey.OBDLink LX OBD2 Bluetooth Scanner for Android and Windows
Amazon.com: OBDLink LX OBD2 Bluetooth Scanner for Android and Windows : Automotive
Buy OBDLink LX OBD2 Bluetooth Scanner for Android and Windows: Code Readers & Scan Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
