1 - 6 of 6 Posts
I took the sunroof off my 95vr4 a long time ago and ever since I put the damn thing back on it makes the most annoying rattling sound I have ever heard. it drives me crazy. It sounds like my car is falling apart. I tried installing it and dropping it back in and it didnt work. I read the FAQ and i need to know what I need to replace or check to keep it from rattling. Please help!
3.2.1.....Go!
TTT
Senior **i.e. OLD** Member
Im not sure what good this info is...but...
If you take the roof out, and lay it on a soft surface (outside down), you'll see some screws holding those two "duck bill" inserts. If you take those off, you'll see another screw (phillips, I believe). Try tightening those. It may help.
Its been a while since I did mine, and I no longer have my 94 VR4, so I cant double check my thoughts...sorry.
Hope this helps.
Bob.
Discussion Starter #6
I will give that a try. hopefully it will work. thank you for the info.
1 - 6 of 6 Posts
