1 - 4 of 4 Posts
I just got done installing my half shaft that I broke a few days ago doing donuts on dry pavement :) I was real careful not to get any grease on the rotor that I took off. I wiped off whatever little bit was smeared on it but I was pulling up real hard on the dust shield trying to get the hub disconnected and I musta bent it in cause after I dropped the car and drove around I could hear all kinds of scraping. so I pulled over and sure enough the dust sheild was pressed up right against the rotor. There was also a film of grease on the dust shield that I didn't wipe off. Is this gonna cause problems? Cause I'm assuming that some of the grease from the dust shield transfered to the rotor while it was rubbing.
Thanks,
Rob R.
just buy some brake cleaner and clean everything real well it should be fine
1 - 4 of 4 Posts
