21 - 40 of 52 Posts
Robotics Engineer
Discussion Starter · #21 ·
~update~
Jae Harrison's box is ready to ship (y)
I'm taking new orders!
Robotics Engineer
Discussion Starter · #28 ·
Hey everyone, sorry for the late responses on 3SI. Yes that is me (same person). Lexfire81, may you delete or edit your post to remove my last name for privacy on the forum? I'd appreciate that.
I make these boxes all the way up to pre-fabricated with carpet. Still taking orders, have two boxes in the pipeline now. All prefabricated boxes are CNC cut and professionally assembled with a terminal cup (ready to install).
Robotics Engineer
Discussion Starter · #29 ·
Done! Sorry dude
STEALTH SUBWOOFER BOX V1
Hello all, happy to finally announce that my custom subwoofer box I designed and engineered for optimal sharp deep bass response is finally available. The Stealth Subwoofer Box is the subwoofer solution you've all been asking for and needed. This is a sealed subwoofer enclosure setup for 2 10' woofers, however you may modify for 8' woofers or odd shapes such as square type Kicker brand woofers (if that's your thing). I recommend going with dual 10" woofers. 12" woofers will not work in this cavity, just not enough room to achieve this; figured I'd mention this in advance since many would be curious. Two 10" is more than sufficient to achieve accurate clean deep bass in our cars, especially with an appropriate audio setup where you have crossovers and/or digital tuning between your highs, mids, and lows. This is not meant to be an SPL competition winning solution; the goal of this box was to provide an OEM+ quality solution without reducing accessibility of the rear hatch and storage by utilizing the notch behind the seats.
Features:
  • Stealth design - utilizes notched down space behind seats
  • Retain usability of rear bucket seats for passengers or storage
  • Seats up or down at any time (down for the visual appeal)
  • No fastening system or modifying the frame involved - uses geometry of rear seat area and hatch for safe and secure mounting
  • Easy no tools required removal for track days, cleaning, or folding seats down for additional cargo room
  • Optimal air volume for dual 10" woofers intended for sealed enclosures
  • Designed to allow spare tire access to be creeped up for access to storage compartments
  • Easy mono-amp mounting of Rockford Fosgate T500X1BR or JL MX500/1 or similar amplifiers on rear face
  • Proper tolerance for power and audio cables between subwoofer and frame
  • Quality OEM matched carpet for fabricated box
https://scontent-bos3-1.xx.fbcdn.net/v/t1.15752-9/s2048x2048/93486463_770305103908777_6155758728780972032_n.jpg?_nc_cat=105&_nc_sid=b96e70&_nc_ohc=bED0HGUyxFwAX-aotyS&_nc_ht=scontent-bos3-1.xx&_nc_tp=7&oh=d3e1cfab9da51ef339e1987d1f3c69cc&oe=5EBC9C19
Under advisement from other owners I previewed this design to, I have decided to offer multiple ways for you to utilize my design. You can buy this as a fabricated ready to install solution or you may buy plans to build this on your own and modify/tweak it as needed for your situation. Building this on your own would indeed save you some money, but takes tools, time, possible frustration if this is new to you, and material costs. My fabricated boxes are professionally CNC'd (cut by a computerized industrial router) and fabricated; I have partnered with a local fabrication shop to provide this to solution with reasonable timing and exceeding quality. Shipping a subwoofer box safely is a pain in the butt, but I have come up with a way to ship these to your home without worry.
For removable sunroof and strut bar owners:
I do not have a version released yet that I feel comfortable with. Once I do I will release the plans for that design and offer that version in addition to this one. I am close. You are free to buy these plans and not wait for me though.
Send Payment(s) To:
Please indicate what you are buying and your address with ZIP code. If purchasing plans you must sign the disclosure I have attached below and email it to "[email protected]". The disclosure is just to protect me and the design from others sharing without paying for the design license. As you see with the plan options, you may purchase a digital model in addition to physical plans. Physical plans will be mailed. The digital models will be provided once the first few rounds of orders are through.
PDF Plans: $55 shipped
(option) digital plans + model +$35
1:1 Scale Plans: $75 shipped
This is ideal if you do not want to do any measurements and would rather use a pattern to cut the pieces out (like model airplanes)
Fabricated Box: $450 + shipping
CNC cut to exact measurements, assembled professionally, 3/4 inch MDF, all joints wood glued and silicon sealant to prevent air leakage, fully carpeted, terminal cup installation ( you may choose to disclude this if you want to install your own or go a different route on placement and type of termination such as through hole terminal bolts). If you want to make custom cutouts and have something specific in mind please let me know at [email protected]; I'll try my best to accommodate any requests.
(Option) - You may request saddle-tan carpeting that matches the tan interiors; this creates a uniform look. This is a good option if you plan to cover the rear face with a styling plate.
Order Timing:
Plans will be mailed out once I have confirmed receipt of disclosure as soon as possible. Fabricated box orders will be FIFO (first in first out). Be sure to get your fabrication order placed quickly, because these are crafted one by one in the USA. currently I plan to begin getting boxes shipped out the beginning of May. As the list grows you may find yourself further along. Either way I will keep everyone posted here with timing on each box. Be sure to send me your address and zip code as shipping is a seperate charge and will be charged once your box is ready to be shipped.
Send Payment(s) To:
does it come with the actual subs or just the box?
Robotics Engineer
Discussion Starter · #32 ·
I am selling custom subwoofer boxes for the 3000GT / Stealth that make use of the space behind the seats for an OEM / clean yet fully functional setup. Just the box.
Robotics Engineer
Discussion Starter · #33 ·
291233
291234
Robotics Engineer
Discussion Starter · #34 ·
291236
291237
Robotics Engineer
Discussion Starter · #35 ·
Update:
Another box shipped today. Another in the pipeline. Getting ready to ship another. Currently taking new orders, COVID price to be removed soon. Last chance before the price goes back up to $450 per box. $315 is a good deal for a custom & vetted box, for a point of reference most professional audio shops charge anywhere from $500-700 to design and build a custom fit box. If you want one before the holidays, order now as you may not be able to get one in time. These take time to make and the CNC machine gets backed up with other projects for the holidays.
Robotics Engineer
Discussion Starter · #36 ·
Rear view (Cargo cover missing however can be installed with box)
291238
Robotics Engineer
Discussion Starter · #37 ·
291239
291241
Robotics Engineer
Discussion Starter · #38 ·
Price to jump back up to $450 following this week. Last chance to get them at the COVID economy price. I have capacity to possible get a couple out before Christmas. First come first serve.
Robotics Engineer
Discussion Starter · #39 ·
Another one in the books.
For those that get the below reference, bless your soul.
291671
Senior **i.e. OLD** Member
While I appreciated your moxy for design.
I do not appreciate your "COVID" sale slant...
Bob.
  • Like
Reactions: DRIFTIR
21 - 40 of 52 Posts
