1 - 14 of 14 Posts
Keith
Custom built intake manifold. Been running this on my car for a while now. I like it a lot. But I'm going a different route.
PM me here or send me a text at 407 791 1229.
The intake manifold also includes a custom made throttle cable and bracket. Stock stripped down throttle body and newer TPS. The vacuum ports are stainless push connect fittings for PTFE or Nylon style hard line. But could be removed for normal style barbed fittings if using rubber/silicone hose. The port for the brake booster is also a push connect fitting and uses 1/2" rubber hose. I will include the hose I use for this as well with extra length so you can cut to fit for your liking.
YES. You can access the rear spark plugs and wires WITHOUT removing the manifold. Just need to use a swivel on your spark plug socket.
DISCLAIMER: This may or may NOT be a direct fit. My hood is NOT STOCK. It comes very close to touching. I do not know if it will clear a stock hood with 100% certainty. Obviously will NOT fit a normal Y pipe to the stock TB. The angle and placement has changed. Also... NOT A show peice. Was designed and built with function over form! Do not expect some polished IG art piece. Expect something that has A LOT of design and time put in to WORK and work well!
This manifold is custom built. 1 of 1. Be cool. Buy this! Lol
Feel free to ask any questions or request specific pictures of something.
I"m asking $1250 for everything meantioned. Manifold, SS fittings TB & TPS, Throttle cable and bracket. Brake booster hose.
Keith
Discussion Starter #2
Also! If you are interested. I have tapped and installed steal Helicoil threads in the lower intake. I am using Stainless cap screws for better torque and sealing under higher boost. I can add this in for a package deal!
Just let me know if you want the lower intake and hardware as well!
Keith
Also accepting trades and trade plus cash. Here are a few things I am interested in:
VERY light weight wheel and tire set up. 16” or 17”
Carbon hatch and Lexan window
Carbon Driveshaft (6 speed)
6 Speed tranny and transfer case
Kirkey Aluminum Seats (or other sub 13lb seats)
Manual door (roll up) internal door parts.
Misc. 2.5”, and 3” aluminum tubing
Bosch 044 External Fuel Pump
MR2 00-05 Electric Power Steering Pump
STALKER
<a href="https://ibb.co/Th1QXZB"><img src="https://i.ibb.co/2KSz2w7/65288805-635833263597243-1346519062439526400-n.jpg" alt="65288805-635833263597243-1346519062439526400-n" border="0"></a>
<a href="https://ibb.co/MnwPkGm"><img src="https://i.ibb.co/R2rQTBq/65319400-2370979496479330-2269466401448132608-n.jpg" alt="65319400-2370979496479330-2269466401448132608-n" border="0"></a>
<a href="https://ibb.co/8mkP8j1"><img src="https://i.ibb.co/Prk1C5q/65512398-392620811603513-1787390901253832704-n.jpg" alt="65512398-392620811603513-1787390901253832704-n" border="0"></a><br /><a target='_blank' href='</a><br />
STALKER
Should of asked for more than $700 Aye TUFFTR...
Also will 100% hit the hood.
One fix at a time
Custom intake manifolds are not selling for very much lately. I had a better driver's side one with shorter runners, bigger surge tank, and a billet Mustang TB included and there was no interest even at $700. I ended up trading it and some other parts for a DR-800 kit. The last modified intake I saw go for a decent price was a DR 90mm intake that sold for $700 a few months ago.
Keith
Discussion Starter #11
The white one posted above is different from what I started with… I think anyways.
This one had the throttle body facing the driver side of the car. I cut the plenum off, flipped it, added a half round lower portion and modified the inside further. I also machined down the length of the runners at the flange to lower the intake height as well as shorten it.
I daily drive with this intake still currently installed. It does NOT hit my hood. But my hood is not stock, so I can not be sure it will fit under all hoods.
Keith
Discussion Starter #12
This one does come with custom throttle cable (Not modified stock) and other bits to bolt on and go. I have a lot of time into it. I did not just cut up a manifold and make it work. I thought it out and tried to get the correct runner length and plenum volume.
But as I haven't had too much interest here. I'll hold out for a good trade.
I prefer to barter these days anyway.
One fix at a time
That's what ended up working out for me better was bartering.
Keith
Discussion Starter #14
accepting trade offers!
CF Driveshaft
CF Hatch
Lighter brakes
Kirkey Aluminum seat (or other light weight seats)
anything thast makes the car lighter!
Bosch 044 external Fuel pump
8 Gallon fuel cell
6 Speed AWD Tranny
6 Speed AWD Transfer case
1 - 14 of 14 Posts
