I have a 91 Stealth SOHC 5spd that I've been having some troubles with. I bought it not running and found that the ecu was bad so I bought a rebuilt one to put in it. This allowed the car to start but it was missing pretty badly and, long story short, after some troubleshooting bought another ecu and it started running like it should.
It's been about a year since then and I just recently replaced the stock fuel line with some 6an summitracing ptfe lines and after assembling it I found that the fuel pump would constantly prime with the key in the on position (which it didn't do before and, afaik, shouldn't). Also, I changed the fuel line because of some unrelated issues (I'm trying to keep this car mostly stock). I figured it might be leaking but it has good fuel pressure and runs just fine without any leaks. After a bit of troubleshooting and testing relays I decided to swap in the rebuilt ecu to test and now it doesn't prime just like it's supposed to and starts fine, albeit with the aforementioned missing cylinders.
All the ecus have the number MD153354 E2T35372. Not sure if it matters but each one has a different number and letter beneath the e2t number.
tl:dr I have 3 ecu's with issues. I don't want to buy another one if I don't have to but it seems more expensive to rebuild than to just get another one. I have a soldering iron and could attempt to frankenstein them together but I don't have much experience doing that sort of thing. Also I wouldnt even know what I'm looking for lol. I could just live with the constant priming but it's particularly annoying since I know it's not supposed to. Any advice/info would be appreciated.
