1 - 3 of 3 Posts
E
Guest
The cooling warning light stays on when the car is cold, then goes on and off and finally stays off after about 5 minutes of driving.
The coolant level in the reservoir is fine.
Anyone else had this problem or know how to correct it?
I don't think it's a serious problem, more of a nuisance.
Thanks,
Ed
S
Guest
Mine does that exact same thing, but only when the temp drops below about 20 degrees. Then after about 5 minutes it is fine and the coolant level IS normal.
todd
'94 VR4
1 - 3 of 3 Posts
