1 - 2 of 2 Posts
Large Member
I'm pretty sure I have a coolant leak.. and most of you say its probably the water pump..
Would that STOP-LEAK stuff work?? Where would you add it??
-LDG
93 Stealth ES
Banned
If its the water pump the stop leak will not work. I tried that trick on my mini van :( I had to replace the water pump, timing belt! to the tune of a $700 repair. When the pump seized it tore up the timing belt, I'm lucky the van was at idle when it went, It would have been a major engine repair otherwise.
Don't risk it with the 3000GT.
Alan
1 - 2 of 2 Posts
