81 - 100 of 108 Posts
Discussion Starter #87
Is there a discount if I want it as a kit to do the soldering myself?
Sure if you like, although this device is mostly surface mount components SMD 1206. $20 saving.
If you want to solder up the OBD2/MUT cable also, there's another $10 savings in that.
Awesome - it's probably just worth having you do it, but I like having options :D I'll be ready to get one probably before winter!
Shipping to UK via Airmail with no tracking is no additional cost. However, tracking is $30 USD extra.
Cheers, and its just plug and play then using an ODBII Bluetooth adaptor? Apologies, but the last time i tried to log a GTOP was over 15 years ago with a hand held palm device using a serial connector!:) Have not found anything in the UK close to what you are producing.
Thanks
Discussion Starter #96
That is right, plug and play with OBD2 ELM327 compatible Bluetooth adapter. Someone made a in depth review of this product somewhere on this forum, covering advance features. Only when you do advanced stuff, such as attaching extra sensors do you need to configure it, and then it's not plug and play anymore. :)
Discussion Starter #100
At the moment you cannot do any diagnostic testing, other than checking / clear engine codes. I just checked the Torque app, and noticed I can define custom Diagnostic Tests, so it is possible -- it will require me to do some more research / testing before I release a software update.
