After work on Saturday I go to shift into first but there's no pressure when I depress the clutch pedal. I check the clutch fluid and its low so I fill it, no luck. Then I get somebody to help me bleed it but it still doesn't work. Now when I press the clutch there is a little pressure at the bottom but still doesn't shift and it won't come up all the way by itself. So I geuss I'll get it towed to that Mitsu dealer, which is right down the street, and get them to look at it, unless you guys have any ideas. I think its the clutch release(slave) cylinder, but that looks like it's a little hard to change.
