Well, after doing a search on clutch and pedal and sticks I've decided to run this by you guys and see what you think could be the problem... if it really is a problem to be concerned with.
Sometimes after shifting the clutch pedal will kind of "stick" as I'm letting it come back up. It isn't a "stuck" kind of thing, just a small spot of resistence as the pedal travels back up. It happens about 1/2 way of the pedal travel, and it doesn't happen all the time. It's really hard to describe better than that without letting someone just drive the car and feel it.
Has anyone had something like this happen to them, and if so, what ws the problem / how do you repair it? Is it something to worry about, or is this a normal cold temperature thing? Any help would be appreciated.
