1 - 2 of 2 Posts
R
Guest
Anyone else try feeling the clutch pedal in left hand turns? Check it out, see if any difference in position of clutch engagment during left turns.
ray,
no ideas here...but you should try to ground pin 1 of the scan tool socket to ground..if you have a 94-95...then the engine check lite will light up with the patterns...I hope this helps
1 - 2 of 2 Posts
