Ok heres the problem. My clutch, which until today worked fine, is now going to the floor so easy one could blow on it. Then it does not pop back into the upright position. It just stays there for a second, as if held by a sticky piece of old gum, then slowly comes back up into position. Since this started happening it is increasingly hard to shift. I dont know what the problem could be. Maybe theres no presure in the lines. Because the clutch feels the same way your breaks do if you have air in your lines and need to bleed them. I dont know.....help?!?
