1 - 6 of 6 Posts
You could go to your local Performance Shop and ask them to grind - down your Stock Flywheel to 12 lbs. Most of the ones that are sold are 9lbs if I am not mistaken. Such as the Buzzspeed one and the Fidanza one. ;)
I almost forgot ~~~ The 12lbs will help your car not drop the RPMs so fast as the 9lbs will drop your RPMs. ;) But you should just check at your local shop and make sure they can do it. It will be a hell of a lot cheaper than buying it for about $300 - $400 and than having them install it for more money. ;)
Waitta minute, are you saying that these DSM flywheels work on our cars? I know that our transmissions (FWD) are almost the same, but what of this 6 or 7 option?(look at the website, go to drivetrain, and then to the bottom)
Well the DSM Lightened Flywheel is $390 and over $400 with shipping and handling. If you do not intend on getting your stock one shaved off you might as well get a Fidanza. Most people on the board highly recommend them. ;)
1 - 6 of 6 Posts
