Here you go!!!!--->>
GOOD NEWS! Carfax search results confirm this 1993 Toyota Supra (JT2JA82J7P0006743) qualifies for the $5,000 Clean Title History Guarantee. By ordering this Carfax Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Section #: Section Name: Section Results:
Vehicle Specifications JT2JA82J7P0006743
1993 Toyota Supra
Title Check Clean Title History Guaranteed
Odometer Rollback Check No Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registrations
Vehicle History Details 6 Total Vehicle History Records Found
NOTE: Carfax has not inspected this vehicle. It may have problems that have not been reported to Carfax.
How did Carfax analyze this vehicle's history?
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JT2JA82J7P0006743
1993 Toyota Supra
2D H/B Subcompact car
2954cc L6 Turbo EFI
Gasoline
Rear-wheel drive
Turbocharged
Japan
GOOD NEWS! Carfax search results confirm this 1993 Toyota Supra (JT2JA82J7P0006743) qualifies for the Carfax $5,000 Clean Title History Guarantee. Carfax analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problem Titles Checked: Results:
Salvage/Junk Checked - No Salvage/Junk Title Found
Rebuilt/Reconstructed Checked - No Rebuilt/Reconstructed Title Found
Flood Damage Checked - No Flood Damage Title Found
Damage Disclosure Checked - No Damage Disclosure Found
Manufacturer Buyback (LEMON) Checked - No Manufacturer Buyback Found
Exceeds Mechanical Limits (EML) Checked - No EML Found
Not Actual Mileage (NAM) Checked - No NAM Found
NOTE: Click here for a complete Carfax Glossary.
GOOD NEWS! Carfax search results on this 1993 Toyota Supra (JT2JA82J7P0006743) did not uncover a potential odometer rollback. Carfax analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
Date Reported: Odometer Reading:
12/01/1993 45
12/02/1995 11,350
02/15/1997 21,948
10/29/1997 22,339
08/01/2001 64,650
GOOD NEWS! Carfax search results on this 1993 Toyota Supra (JT2JA82J7P0006743) did not uncover any of the following problems:
Problems Checked: Results:
Accident Checked - No Accident Record Found
Salvage Auction Checked - No Salvage Auction Record Found
Failed Emissions Inspection Checked - No Failed Emissions Record Found
Fire Damage Checked - No Fire Damage Record Found
Crash Test Vehicle Checked - No Crash Test Vehicle Record Found
Grey Market Vehicle Checked - No Grey Market Vehicle Record Found
Carfax search results on this 1993 Toyota Supra (JT2JA82J7P0006743) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - No Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
The Carfax database contains a total of 6 vehicle history records on this 1993 Toyota Supra (JT2JA82J7P0006743):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
09/01/1993 Texas
Motor Vehicle Dept.
Houston, TX
Registered as private vehicle
12/01/1993 45 Texas
Motor Vehicle Dept.
Houston, TX
Title #41106852
Title or registration issued
First lien reported
12/02/1995 11,350 Texas
Motor Vehicle Dept.
Spring, TX
Title #00022200049116171
02/15/1997 21,948 Texas
Inspection Station
Houston, TX
Passed emissions inspection
10/29/1997 22,339 Texas
Motor Vehicle Dept.
Spring, TX
Title #17030635721133739
08/01/2001 64,650 Wisconsin
Motor Vehicle Dept.
Eau Claire, WI
Title #01213E3001
Odometer reading recorded on 08/01/2001
NOTES:
You have significantly reduced your risk of purchasing a vehicle with a hidden problem. However, Carfax has not inspected this vehicle. There could be other potential problems with this vehicle that have not been reported to Carfax.
Not all titles issued represent a change in vehicle ownership. For example, a title could be issued to reflect an address change or correction.
PRINT AND SAVE THIS GUARANTEE ALONG WITH THE FULL REPORT
A Three-Year, Transferable Protection Plan
Carfax's $5,000 Guarantee confirms this 1993 Toyota Supra (JT2JA82J7P0006743) has a Clean Title History. This certificate is valid for three years from date of issue, and is transferable!
Carfax $5,000 Clean Title History Guarantee Terms:
Vehicle ID Number (VIN): JT2JA82J7P0006743
Year/Make/Model: 1993 Toyota Supra
Issue Date:
10/30/2001
Expiration Date: 10/30/2004
Register your $5,000 Guarantee with CARFAX
Three-year Protection Plan:
During the next three years, should you discover a problem title in this vehicle's history which was not included in this Carfax Report, Carfax will pay you 10% of the vehicle's wholesale value - up to $5,000!
Transferable Protection:
This Guarantee is transferable should you sell this vehicle prior to the Guarantee expiration date. The new owner receives the same protection plan coverage for the balance of the Guarantee's term.
*Carfax agrees to pay to the holder of this report 10% of the wholesale value of the car, up to $5,000 if Section 2 of this report indicates a Clean Title History and a Problem Title actually exists for this vehicle. A Problem Title is defined as a passenger motor vehicle ownership document issued by the state that bears the word or symbol signifying that the vehicle was salvaged or junked; rebuilt or reconstructed; flood damaged; disclosed as damaged; bought back by the manufacturer; odometer exceeds mechanical limits; odometer was not the actual mileage; or any other symbol or word of like kind. Guarantee Certificate along with corresponding full report must be presented in order to be eligible for payment.
View complete Terms and Conditions. Register your $5,000 Guarantee with CARFAX
In appreciation for your business, we offer our valued customers additional useful services and auto-related savings opportunities. Here are several special offers provided by Carfax and our selected partners to further assist you in the car buying process.
Thanks for using Carfax!
Carfax has screened and selected for you the very best providers who offer quality products and service at low prices. Shop these providers with confidence thanks to Carfax.
Warranties Insurance Finance
Carfax Disclaimer:
CARFAX DEPENDS ON ITS SOURCES FOR THE ACCURACY AND RELIABILITY OF ITS INFORMATION. THEREFORE, NO RESPONSIBILITY IS ASSUMED BY CARFAX OR ITS AGENTS FOR ERRORS OR OMISSIONS IN THIS REPORT. CARFAX FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. CARFAX®
Customer Service:
[email protected]
www.carfax.com
© 2001 Carfax, Inc., an R.L. Polk & Co. All rights reserved.
30.Oct.2001 08:48:07
