I hate to have to ask this, but are you ABSOLUTELY sure your making good contact thru these connections and that you have a GOOD set of jumper cables?Ive been running jumpers from my battery to the terminals that connect to original battery..😬
Can't quite understand this because of placement of question mark. Are you asking if this is a motor mount? If so I'm not sure because of picture angle I can't make out what I know a motor mount to look like. Normally torque specs are listed in service manual but don't recall size and pitch listed.Those two bolts i was asking about before? Motor mounts.
yea i coudnt seem to find what bolts they were in the manual. This mount was very easily visible from the front of that car and i guess i didnt notice it. That wire harness near the front of the car for that AC fan has those 3 wires sticking out about an inch.. So i assuming i have to open up that harness and get some room? Or do you think i could make that splice without having to get in the harness?Can't quite understand this because of placement of question mark. Are you asking if this is a motor mount? If so I'm not sure because of picture angle I can't make out what I know a motor mount to look like. Normally torque specs are listed in service manual but don't recall size and pitch listed.
Edit: Oh Wait .... I think I can make out top of the transmission mount near the strut tower just below the the white circles. So they do appear to be motor mount bolts.
Man you jump from one spot to another without ever making any corrections to the last subject you were on, it’s hard for me to even concentrate on one subject that you don’t bother to even give answers too. Example (only one) where did the two unseen wires terminate from the oval connector near wiper motor in one of the jumps. Now you’re back to the wires sticking out near the left front light (I think) that you completely ignored back then and as far as I know you never located wires/connector from A/C relay box that they need to attach to.That wire harness near the front of the car for that AC fan has those 3 wires sticking out about an inch.. So i assuming i have to open up that harness and get some room? Or do you think i could make that splice without having to get in the harness?
Haven't got to removing the battery tray for a better look at em. It was a long day, went to start the car and it had no crank so I had to get it in the garage before it snowed, upon getting that done I quickly removed the starter and looked looked towards the spot you specified and noticed that harness with the wires sticking out as well as the motor mount bracket. It was very cold so I wanted to get inside.Example (only one) where did the two unseen wires terminate from the oval connector near wiper motor in one of the jumps.
Yes I found the box, underneath the box was a harness and on that harness was the 3 wires that were chewed just sticking out of it an inch. I think you mentioned that those wires led to this box but from what I'm seeing they lead to a bundle of wires which then feed into the box. (could be what you meant)and as far as I know you never located wires/connector from A/C relay box that they need to attach to.
First I'll say I'm a slow two finger typer, which causes me to consume a lot of time with even a simple paragraph and causes many errors because my brain refuses to move that slow. For that reason I don't like to go back and repeat things over later.Yes I found the box, underneath the box was a harness and on that harness was the 3 wires that were chewed just sticking out of it an inch. I think you mentioned that those wires led to this box but from what I'm seeing they lead to a bundle of wires which then feed into the box. (could be what you meant)
After looking at this statement closer, are you saying there’s wires chewed under the relay box in addition to the ones you showed in the picture?Yes I found the box, underneath the box was a harness and on that harness was the 3 wires that were chewed just sticking out of it an inch.
I definitely understand what you mean about taking time to get that info for me and portraying it in a useful way and I'm really grateful. There's been a lot of it and I apologize if some of it went over my head.Back when talking about chewed up wires from that relay box to A/C fan, I explained they would lead to an area with a connector A-37 (IIRC) and explained that connector might be in the area of the refrigerant drier, I even explained what that looked like.
No just the 3 wires leading to ac fan clips.After looking at this statement closer, are you saying there’s wires chewed under the relay box in addition to the ones you showed in the picture?
Yea positive, the volt gauge shows about 12 or 13 volts, if it doesn't I just mess with the connections.hate to have to ask this, but are you ABSOLUTELY sure your making good contact thru these connections and that you have a GOOD set of jumper cables
Don’t think we’ve come to complete understanding yet concerning three wire ends shown in first picture of your #85 post. The still attached ends should lead to the 2 connectors of the second picture, which are the 2 connectors for A/C fan. The unattached ends must have three other unattached ends that they were connected to at one time; you need to find the other three unattached ends (not shown) as those two sets of loose ends need to be reattached together. The hidden ends may be tight to a bundle and not sticking out like the ones shown in picture, the shown loose end seems to have been under top lip of headlight support bulk head before pulled up on top of it. I’d expect to see the other three matching loose ends sort of below the same lip somewhere behind headlight, maybe in area of refrigerant drier (item with red cap on line and red harness connector attached to top).......... I found the harness leading to the two clips you were mentioning. The harness leads to the clips right below the ac relay box. The AC fan wires are the only ones sticking out of that harness in that area........
No just the 3 wires leading to ac fan clips.........
If working correctly the cooling fan shouldn't come on when car is first started cold. It should only start after engine has run long enough to reach ~ 185 degrees, so it’s not working right either, which might have been original problem with engine overheating. Best I can say is you’ll need to address one issue at a time until both are corrected.Also for some reason the cooling fan kicks off intermittently. Sometimes it will stay on with car running (heat or not) and sometimes it won't run at all. I didn't readily notice any chewed wires in the general area of cooling fan
Right, i got lucky as the unattached ends not shown in pics are sticking out of the bundle of wires about an inch or two right below where the wires are in the picture. Exactly where you're describing. I may have left that out before.The unattached ends must have three other unattached ends that they were connected to at one time; you need to find the other three unattached ends (not shown) as those two sets of loose ends need to be reattached together
Yea I noticed that too, I can't imagine it be very difficult to fix. I went to home depot and bought a bit of wire that is similar in gauge but the strands themselves are really thick and hard to work and move. I am gonna check other places for some wireAlso the same wire (can’t make out color) from first picture that has a short missing section of (right) connector of second picture needs to be reconnected to pin inside that connector, or completely replaced from the connector pin to the unseen loose end discussed above of same colored wire. Also looking at (second picture) wires from left connector the broken and exposed wire should also be replaced.
Yeah, that's where gauge of wire comes in, so you'd want a smaller gauge of wire. In case you don't already know a higher gauge number is a smaller wire (opposite of what you might think), sort of like gauges of a shotgun shell if your familiar with those. Also single strand wire is stiff verses multi-stand, you'd want wire like from auto parts stores.I went to home depot and bought a bit of wire that is similar in gauge but the strands themselves are really thick and hard to work and move. I am gonna check other places for some wire
