"VERY" spacey interior!!!!
Bob.
Bob.
Damn Bob, you jumped me off the starting line again.Hrmmm...
TWO MFI relays?????
Bob.
2 MFI relays. I didn't catch that. Had to go back and look at the pictures again. In the other posts recently about car not running I posted a picture of that circuit.@Jhorst442 After making my above replay to Bob @OhioSpyderman about MFI relay, I find it strange it appears to be 2 MFI relays side by side just back of ECU in picture you posted of interior. Only one is plugged it, but it appears the harness can be switched to the other. Don’t know MFI relay was problem in past, being reason for a mounted spare
Though some have gone bad, that’s not the norm. They’re usually very reliable, in fact the over 29 year old ’93 listed in my avatar with ~ 150K miles is still running on the original MFI relay. Even in original location to right of radio (see attached picture) and with carpet covered particle board resting against outside, they don’t normally overheat.Don't those relays just get too hot or too cold and bad solder joints lead to a non working relay. But after the temperature regulates, they work fine?
Have we looked at the coils?Ok. I'll definitely dig into this deeper. Thank you
I have a base model, so I haven't worked on a TT and glanced through the posts. I didn't see the coils mentioned. Particularly if it had racing coils in it since they don't last. They sometimes work intermittently when bad making it hard to diagnose. Possibly the ignition control module too.Ok. I'll definitely dig into this deeper. Thank you
I have a 92 3000gt, and I was having problems with starting and rough running engine. Everyone had an idea of what could be the cause, but until I got one of the Black Stealth obd1 scanners. I did a scan several times, and it kept coming back with Engine Coolant Temperature Control sensor. I thought that was all about engine coolant and figured that couldn't be it. After some research and found that that sensor does a lot more because it also controls the air/fuel mixture going to the engine. I check around to see what where I could find one. I found one at Pit Stop Auto in Mansfield, Texas. You can find them online. The sensor cost me $28.96. It's right at the top of the engine, so it's a quick exchange. It runs like new now.Pull the ECU and check for leaking capacitors.
30 minute job to pull.
Most can be repaired.
Bob.
