1 - 12 of 12 Posts
THE GAME
hey , i just got a used Cap and i wanted to know if i have to charge it a special way or something before i just hook it up to the amp?
The cap uses the power from the battery. I believe that you put your cord from the battery to the cap first, then relay the cord from the cap to your amp. You shouldn't have to charge it a special way. Hope this helps
Rich
THE GAME
Thanks , but i know how to hook it up .I just heard that sometimes they need to be charged up a certain way when they are brand new or haven't been used in a while
Well, I just did alittle research, and this is what I found:
This is simply done by either putting a resistor (1k-ohm or more) or a test light between the positive post of the battery and the positive terminal of the cap (with ground hooked up to metal). After a few minutes, the capacitor will be charged up, and it can be connected
Hope this helps better :)
Rich
THE GAME
Discussion Starter #5
i found the manual online for my cap so it gives the directions on what i have to do. And yes , it does have to be charged.
OG *** Member
You should never handle charged capacitors, especially of that size. You could very easily have a lethal charge across it's terminals. After you charge it for the first time (if really necessary) completely discharge it. I can't imagine why you would need it initially charged however.
THE GAME
Discussion Starter #7
the manual says to charge it before use so thats what i am gonna do. And what do you mean by lethal charge?
OG *** Member
Capacitance * Voltage = Charge
If you have a 1F cap and you charge it at 14V will have a ~14 Coloumb charge across it's terminals. That would kill you if it passed through your body.
Just for fun, charge the cap then put a screw driver across it's terminals. Try it, you'll think twice before handling it with your bare hands.
THE GAME
Discussion Starter #9
ok genius , and why would the current pass through my body? i ain't planning on putting any screwdriver across the terminals. And all the stereo installers handle them with bare hands so why can't i?
OG *** Member
Your body has a lower resistance then air, if you connect yourself between the terminals (ie: you accidentally placed your hand across the cap posts) charge will pass through your body.
If an audio installer is handling a capacitor, you can bet it's been discharged. You never handle a charged capacitor without gloves and rubber boots. Most digital caps today have discharge circuits built into them for safety, and thus you wouldn't have to worry about it.
THE GAME
Discussion Starter #11
well i am wasn't planning on putting my hand across the posts either. I know this stuff can be dangerous but i have common sense so i'm sure it will work out fine.
OG *** Member
Trust me, accidents happen, so don't risk it. 15C through your heart will kill you dead or send you into fibulation. Wear gloves.
1 - 12 of 12 Posts
