1 - 5 of 5 Posts
how does getting good cams help?
what do cams do??
and how much power would they give you?
and in your opinions
where along a modification line should it be done early or later?
my verbage and use of terms and what not might not be perfect here but you'll get the idea i think: cams, regulate the opening/closing of your valves. a "good" cam would essentially allow your valves to open more, therefore allowing more air into the compression chamber and then allow exhaust to flow more freely out of the compression chamber.
THANX for ur help i appreciate it
cams
there is a company called pit road m who makes some really good cams for vr4's and rt turbos. i think you can get them from gt pro
Discussion Starter #5
gt pro eh?
thanx for the info
1 - 5 of 5 Posts
