1 - 3 of 3 Posts
'94 3000GT original owner
Hey Brian,
Can you find out for sure if the Eclipse GST (FWD) tranny is the same tranny used in the 3000GT FWD? The parts book uses the same number for both trannys but there are some different letters after the numbers. If the trannys are the same, finding a limited slip diff won't be a problem.
Thanks
I don't think there is any way that they can be the same tranny since they use different blocks completely. The Eclipse GST (1991-1998) have a TD05 turbocharged inline 4 (block 4G63). As you know we have a V6 configuration (block 6G72) and I don't see how very many parts (like flywheel for example) could be interchangeable on those 2 engines. So I don't think these trannys are interchangeable.
I'm not Brian (grin) but just thought I'd share my .02. Brian .. (or anyone) if I am wrong please correct me.
Mark
'93 RT TT
As far as I know tha internals are the same. BUT I will need to break out the fische and check it for sure, then I will post the results.
1 - 3 of 3 Posts
