1 - 2 of 2 Posts
Senior Member
After installing my Greddy BOV, I keep noticing the following:
Under boost, if I retard the throttle even the SLIGHTEST bit, the BOV blows off and the boost immediately drops to ~20psi vacuum. I've adjusted the BOV toward the "harder" setting but it still does it. Could this problem be a sign of a faulty BOV? What other options are there?
On a related note, I'm noticing a pronounced hesitation between 2K-3Krpms at WOT. Could this problem stem from the same cause?
More Than Meets the Eye
It's the -20 vacuum that's causing it to blow off. The settings on the BOV let you pick the vac level it takes to open. Obviously your car is in that range - anything greater than 20 vac should open the BOV anyway.
1 - 2 of 2 Posts
