Hey guys,
I have a '91 3000gt sl and it is stuck in limp mode. I have replaced the leaking capacitors on both the ECU and TCU.
I've been told I should start with a ECU replacement as it seems to be refurbished around '05.
On both boards the capacitor acid has seemed the surrounding area a bit. I believe there are even a few of the solder "solder pads/rings" (for lack of better name) have been eaten away on one side. (wonder if its possible or best for me to try to fix that...)
Both computers are receiving power, but the car isn't responding to a OBD scanner (according to mechanic). Hence maybe ECU first?
Though if I remove both computers, the car will not start, it will just repetitively fire.
Does this mean that the ECU is in fact working to some extent? or is it just that another part is just recognizing that it is plugged in and "ready" to start.
Anyways, what do you guys think the best (and cheapest) course of action would be? A "new" one, purchased online? A repair service that tests the product before sending back out? Should I start with ECU or TCU?
I would love to know some of your guys opinions and recommendations! It would help me tremendously.
Thank you guys!
Thank you guys!
