1 - 20 of 47 Posts
Fear the Reaper!
Hey all, initial plans were to part out my 1G and use most of the parts for my spyder vr4 build but ended up getting another block for that car. I'm in the process of bringing my 1G back to stock. Car started as a built 16g car but the shop building that car had a terrible machine shop. That motor was toast. Sold most of that setup and got a "JDM" motor. I had alot of trouble with that motor, low compression, overheating, blowing smoke, randomly turning off as I drove. Basically I rebuild the motor, wire harness and now the rear turbo. Plan on pulling off my coilovers, cfds and big brakes for a stock setup soon as well.
How I got it back after the crap shop
Interior wiring was a nightmare
Fear the Reaper!
Discussion Starter #2
After fixing the harness (mostly, a67 terminal was replaced later which caused my car to turn off randomly)
Bay cleaned up
Powdercoated some of my parts
Low compression (guess the front two had a leak between the cylinders)
Rewired fans to work like stock
My new shop :)
Fear the Reaper!
Car at the shop finally (after half a year)
Hood off, getting ready for the big stuff
Took off both heads, measured and sanded by hand
Valve stems removed and replaced
Front and rear cleaned up and sanded down
Heads back on
replacement oil cooler
Fear the Reaper!
Discussion Starter #4
More bling
Timing belt back on along with most of the major components. Oiled up, measured compression 145-150 across the board
Cooling system reinstalled
Pretty much done!
Time for interior work
Fear the Reaper!
Discussion Starter #5
Start of new carpet install
Took off GT-Pro/Greddy FMIC (for my spyder) got a set of SMICs (thanks Syed)
Bumper back on
Gauges installed
Done... So I thought
Fear the Reaper!
Discussion Starter #6
Car buttoned up
Rear turbo shot..
Bearings? What Bearings lol
And that's where I'm at. I have another cartridge on order. Hopefully this will fix the last of my problems
(still need to replace the steering rack)
Senior **i.e. OLD** Member
You mean that German wienie still hasn't finished your Spyder?
Sheesh!
Bob. :)
3SNY - HondaTurtleFTW
Are you going to be selling the non stock stuff you aren't using for the Spyder?
Sent from my ONEPLUS A6013 using Tapatalk
Fear the Reaper!
Discussion Starter #11
What happened to the Spyder?
Still over at Han's place
I have a few things for sale that I'm not using on the spyder, have a set of cianci widebody front carbon fiber vented fenders, an extra sparco pro2000 seat, passenger sparco bracket, few other things. Most of the stuff is going to get used
Sheesh!
Bob. :)
Yeah.... Still has it lol
Fear the Reaper!
Discussion Starter #13
so you finally got a running 3s after how many years now? congrats
Too many.. Usable? Probably over 10 years... Never had the space to do work until now :( Thanks man! Finally haha
Cow man moo?
You inspire me. Thank you for sharing.
Looking really good Frank! Keep up the good work!
Eric
Fear the Reaper!
Discussion Starter #16
Eric
Thanks guys!
Cleaned her up today, got the new cartridge in, just waiting on Cherry hill to send some seals. Really needs a respray though, driver's side is peeling badly
Will keep this updated
Fear the Reaper!
Discussion Starter #20
Thanks fellas! New cartridge came in, swapped it out. Just waiting for seals to ship, should have them mid next week
1 - 20 of 47 Posts
