I have a 1st gen AVC-R and I took a look at the manual for it on apexi's site and have a question about how to calculate duty cycle. I have been using the boost controller on the A mode which has a default duty cycle of 30%.
I have been having trouble making any significant amount of boost in 1st gear and overall the cars boost response feels a little slugish. My car had been running very rich and now that I got the fuel trims in spec the turbo response is better... but I think getting the right duty cycle will make a world of difference.
I looked through the archives trying to find out how to calculate my duty cycle for a given boost level but am confused. I found a good statement by Mark in a post, he said:
"Duty cycle is supposed to be the percentage your stock wastegate setting is of your final boost desired. That is, if your stock wastegate pressure is 5 psi and you wish to boost to 15 psi your duty cycle should be 66%."
How did Mark get 66%? Wouldn't 5/15 = 33%?
I turned off my AVC-R and found that I'm getting .5 kg/cm^2 or 7.11167 psi from the wastegaskets. I'm planning to run .6 kg/cm^2 or 8.53401 psi to start.
So:
7.11167 / 8.53401 = 0.83
Would my duty cycle be 83%?
What would be the way to calculate duty cycle without converting the kg/cm^2 values into psi?
So:
