1 - 4 of 4 Posts
technical so bear with me
I recently had an avc-r installed and I have noticed after searching the archives that others only have either the rpm or the injector duty attached to the ecu via the purple wire. On my unit I can get readings from both rpm and injector duty. So I think this suggests that the purple wire is connected to the injector duty spot on the ecu. Then after reading more of the manual I find that under "ect." and "car select" there is a "cylinder setting". Then it says that this setting should be 1 if the purple wire is connected to the injector signal wire. Meanwhile my cylinder setting is at 6. Also it says for "vehicle speed pulse setting" that all other japanese vehicles should be set to 4 while mine is set at 8. Can anyone clarify this for me and tell me if this is setup correctly. Thanks
chris
1 - 4 of 4 Posts
