Previous Owner had one from them that kinda worked then not too much later it would try to stall at higher rmp, then it sometimes wasnt starting, now i have it and it wont start at all, it's giving error codes 52 and 53, everything upmtomthe ecu is working properly so it looks like it is failing again, are the under lifetime warranty? Transferable?
Iv opened the case and checked to see if they replaced common known problem with the capacitors, they did replace them, one of the processors looks like it is new and freshly soldered. But there is a piggy back board that has corrosion and rust on many of the components, capacitors, resisters, power transistors, it looks like this is a main issue now, they could have/must have noticed it during physical and meter testing.
I don't believe these are being refurbished ect, otherwise these items would have been replaced and the pcb would have been reworked or replaced.
I have photos if anyone is interested.
I am wondering if anyone can tell if the repair is lifetime warranty?
Is there a cheap place where u can buy one remanufactured? Or pulled from wrecked cars
Or another repair company that repairs and warranties these? Any info would be greatly appreciated, thx
