1 - 1 of 1 Posts
the fat and the furriest
1. can i hook the meter to the rear bank under the hood? if so which wire off of the the o2 sensor is it (i think the white one, right behind the mitusbishi on the valve cover)
2. would it work for me to run my hot wire to the hot wire on my greddy turbo timer?
3. if it not, then what if i ran my hot to the hot wire on my dimmer, but the ground to a different, being the dimmer is a rhetostat (spelling is wrong i know) and uses resistance to the ground to dim and brighten the panel.
thanks everyone
1 - 1 of 1 Posts
