1 - 20 of 21 Posts
Twin Turbo
Hi Guys,
Anyone got a spare first gen maf spare? preferably one with 165 E5T05072 on it? I need to maek 100% sure before I buy one etc.
Cheers,
Joe
GTO's a happening
Wish I could help you Joseph. I sold mine to Will (from memory I think it was Will) in Melbourne. If not, someone in Melbourne has it. (stupid alzheimers)
Scotty
4L 6G74 Stroker FWD NA
Joe, If you need a cheap one, TR/TS magna one (4cyl/V6) *should* be the same thing. part numbers may differ but AFAIK contain the same things internally.
$25~ from a wrecker.
Twin Turbo
Discussion Starter · #4 ·
Twin Turbo
Discussion Starter · #5 ·
Scotty
I was actually going to say in my post that "Scotty since your car isn't going you could send me your MAF" LOL then I remembered reading a post somewhere that you sold it cus you don't need it with a stand alone ECU.
Hi Guys,
Cheers,
Joe
Hey mate,
Yep, I got one of those. It was Scotty's too. I forgot that I had it actually.
Do you want me to ship it up to you?
Twin Turbo
Discussion Starter · #8 ·
Hell yes!!!! What numbers are on it BTW?
Twin Turbo
Discussion Starter · #10 ·
HA!!! I just worked out what the 3 digit number means. It's the last 3 digits of the part number. So 165 is part number MD170165. 618 is MD183618. SO the 2 I have tried are 337 and 789 which are MD357337 & MD187789 which are both for N/A models.
Twin Turbo
Discussion Starter · #11 ·
Done!
(I should have had a look when I sent that ECU up to you.)
The numbers are 165 E5T05072 as requested.
You sir, are a legend :bigthumb: :headbang:
Rightio. And both of your N/A ones and your "165" are throwing errors?
Edit: Same address as last time?
Twin Turbo
Discussion Starter · #13 ·
No just the NA ones. The airflow sensor in mine die but the barometric pressure sensor was fine. Which shows up as having issues [code 25] when using the NA ones.
Note: My 165 did give an error [code 12] but pointing to air flow meter but that's it.
Twin Turbo
Discussion Starter · #15 ·
Thanks mate :D
Random question here, if anyones MAF is 100% screwed Can I grab it off you? I need a MAF but dont need what its inside....i.e. will be gutting it so my NA engine bay looks a bit more stock...
let me know! Better then paying for a working one from the wreckers when im only gonna gut it anyway
Twin Turbo
Discussion Starter · #17 ·
I'll let you know how I go. I have it apart and was hoping to clean it properly. If no go it's yours.
I'm a Member
definitely take it apart and clean it...there are diagnostics for it in the manual so I'd give it a 90% chance of being resurrect able or a wiring problem
Twin Turbo
Discussion Starter · #20 ·
Not a wiring problem. Been down that path. Can only be due to dodgy MAF... I hope LOL
1 - 20 of 21 Posts
