Hi all,
Recently I bought a 93 SL to use as a daily driver after a bit of fixing up. I bought the car with the understanding that the transmission was bad. But after spending some time with it I'm not so sure the trans is bad and it may possibly be an electrical issue. It appears that someone has replaced the transmission with a used one with low miles at some point but sadly there was no paperwork regarding when it was done.
So, no matter what gear I select the car will not move, even reverse. The engine only revs and it acts as if the trans is in neutral, meaning the car will roll forward, again even in reverse.
There is no indication that the transmission even goes into gear. There is no sound from the pump (that I can hear at least) or any feeling of the trans going out of/in to drive or reverse. The linkage does move when selecting different gears though.
The fluid is also at the correct level when warm.
Any ideas on where to look next? TCU maybe?
