1 - 10 of 10 Posts
Has anyone had any particular problems tuning the ARC2, running big turbos and injectors?
The setup is IHI BB turbos, 750cc injectors, ARC2, G-Force, FMIC, the works.
*** Edited *** No VPC...
Boost is set at about 1.15 bar...
The car is running really rich, especially at idle.
Anyone have any suggestions, or has anyone had similar problems?
I don't actually have the car yet, so I can't really answer any detailed questions yet.... hopefully the car will be delivered today.
But I'd like to get a jump on a known problem, so I can get to tuning that beast.
If I can't work it out (maybe with Trents help) then maybe I'll take it to Altered since they're reasonable close to me.
i am not a tuner, but i've owned 2 arc2's and it sounds like the mid/low end settings may not tuned properly.
white bread
I had my AFC tuned by Altered and they did a great job. Plus you get the dyno printout so you know what your car is putting down. I know Trent would go down there like once a year and get his vpc tuned, but the ARC is supposed to be real easy to tune. Hope you can figure it out and save a couple hundred bucks.
Jason
I run rich or lean at idle. Rarely does it dither like it's supposed to. I have tried many things with no great success. I am going to try the hotwire mod soon to see if that helps.
Senior Member
I would sell the ARC-2 and G-force and go with the AEM setup. I would also send it down to AAM to have the car dyno tuned after the AEM installation.
Sounds like you found a beast. Good Luck ;)
BTW post some pictures once you get it home
Discussion Starter · #10 ·
Thanks...
for everyone's input.
Carl, I've been thinking about doing just that - I talked to ? from DR and the concensus is that the 750cc injectors are just too big for the ARC to properly control.
Since winter's coming anyway, I might just send it to altered for a rebuild, to get forged internals, and get the AEM at the same time.
Sort of a preventative rebuild, know what I mean? So I don't break something and have to do a rebuild anyway.
I've still got brand new 550cc's, I might swap injectors and see what I can run with just the 550's for now, and do the rebuild later.
See what PSI I can run with the 550's before they're maxed out.
Flyers - sure thing, I'll let ya know what I wind up doing.
1 - 10 of 10 Posts
