1991 VR4, 10:1 compression, mildly ported heads, stock turbos, 3" downpipe, 98 SL flashable ECU
I'm shopping for a clutch kit for my 91 VR4. Currently BPU, but with 10:1 compression running about 12psi on 9B turbos. Maybe 300awhp now, but I'm strongly considering 15T turbos and E85 for future upgrades. Just upgraded the trans to a 300m output shaft and I'm rebuilding the engine with mildly ported heads and a forged crank. I pulled an Exedy stock clutch from the car that was doing fine but looks a little too thin to put back in. It sounds like the Exedy is considered OK to about 400awhp? I'm probably OK at my current level, but it sounds like I would exceed it's capability with my future plans if I put a stock Exedy back in.
I was just about to pull the trigger on an ACT HD street disc(MB2-HDSS) when I came across a company called Action Clutch (https://actionclutch.com/). Their website says they are made in the USA. I've been trying to research them, and come across a lot of discussion on other platforms, but nothing much about 3S's. I think the Throttle Vader build used one, but that's about all I've found. I like the thought of supporting a true US company, if that's truly the case, but their prices seem kind of low for a US manufactured product. Their stage 1 street disc sells for the same price as a stock Exedy. I don't think I've found any negative feedback on them at all though. Anyone on here using their clutches?
