1 - 3 of 3 Posts
If anyone's read my posts about my brake fuse blowing, I did some searching and found Mista Grimm has had the same problems - among others. When my fuse blew the first time, it melted some plastic (maybe damaged the metal contacts) in the interior fuse cluster -- the box below the driver's left knee. I was thinking this plastic cluster must attach to the vehicle wiring harness & should be replaceable as a unit. Anyone here able to verify this ?? Has anyone actually replaced this yet ?? Is this a possible fix for the continuing problems ?
Dope-stoopid yo!
I had these problems too????
Thought it was you ... maybe not
Oh well ... found results in the search engine sometime last week. Thought it was Mista Grimm in there; maybe it was someone else. Question stands though ... anyone ever swapped out the fusebox in the driver's area ??
1 - 3 of 3 Posts
