1 - 3 of 3 Posts
finally got my 93 vr4 from NY, and i am still awaiting my 1st race. i've played with a car little bit, but have yet to try romping on her from a stoplight. it's my first awd car so i was wondering what rpm's are okay to launch at. i've read of people launching from 6K, but will that destroy the the driveshaft or differential or anything? i realize if you do it repeatedly it will, but is it safe once in a while? also how effective is it? is it better to launch from 3K. dump the clutch hard or let it out smooth? any tips would be appreciated. thanks.
mike
14.1 @ 100mph N/A
Unless you're at the drag strip trying for a new record time, launch at about 4500 with a quick slip of the clutch instead of a full clutch dump. That'll save your trans the abuse and still get you off the line quickly.
V
Guest
Launch at 4000 rpm and quickly slip the clutch.That's enought
to put several car length instantly on most of your enemies:)
1 - 3 of 3 Posts
