IMO this is the easiest and simplest way to do it.I'm still fiddling with it. I just cant get it right. I might actually try using just the maft and making small changes with safc2. Im searching for a Chrome ecu or aem maybe also. Im about tired of messing with the safc/maft. Im doing the ray method where you set your base for injector size on the maft and nothing else, and then using the safc2 to do the rest. I did set my fuel pressure back to what it should be according to the manual, and also have an adjustable fpr with a 255 pump.
what problem are you having? trims? tip in? WOT?
post up your settings and a log we can help
