That’s my hope. 2-3 week lead time for axles. Plan to finish suspension and have the car on the ground this weekend to measure for axles. Then work on turbo kit while I wait.
So, we talking another month or so before it moves on it's own power?
Bob.
Big concern is engine right now. CNC-Motorsports are 4-5mo out on shortblock builds. So that’s a No Go. Working with a friend fo Robert Young (FP turbos), that has an old aluminum block resleeved for 427 build that needs some repairs. If he can get that patched up at his machine shop, I can use my crank and rods, order new pistons; rebalance crank, and build my own 427.
Good news, Aluminum block and billet tcase help get the car lighter than expected.
Bad news, I currently don’t have another engine plan unless it’s my old iron stroker which is not my preferred path or swap my stroker kit into an aluminum 5.3 block, that I would need to source and hone out myself to fit my 20 over pistons. That plan also forces me to use my well worn PRC heads. If I can get at least a 4” bore, I can run a loaner set of bad mofo CNC heads from FP.
