441 - 460 of 487 Posts
General & A/V Moderator
I ran into a similar issue with my 74 Diamante lower manifold and the shorter injectors that came with it. The 74 rial has the proper dimensions, but one has to double up the plastic spacers for it to fit properly with our larger injectors.
Discussion Starter #442
It depends on your injectors too. My FIC'S sit further in the injector bung than normal OE style densos. I just had to add a 1/16 spacer, reposition the boss on the rails and fly cut the section where the injector body touched.
Discussion Starter #443
Well Gent's... the FIC 1150cc injectors are out of the picture...
I traded with another member for a Set of Bosch 1600cc CNG injectors. After looking at spray pattern videos and how well they atomize I was pretty sure I'd be very happy with these. They are compatible with Gasoline, Alcohol, LPG/CNG, Methanol etc. But because of the application which they are meant for they are not technically a "bolt-on" affair. Yes it can be hacked and tweaked to sort of work but in the end the possibility of springing a leak and becoming a glorious ball of fire on the side of the track or street is amplified.
So in order to avoid that I'll document the CORRECT modification process for those who are interested.
Bosch CNG/LPG 1600cc injectors as they are (Don't mind the missing pintle caps)
It's been talked about that these have to be modified in order to fit the 3/S fuel rail. Well, here's an in depth look at how I did it. The mini lathe came in very handy at this point.
They do not fit inside the rail far enough due to the resin collar being too wide.
So we chuck it up on a lathe... and machine down the needed amount to fit properly
Here it is after a few passes.
Here is the modifed injector on the left and the Non-modified injector on the right
Clean it up, then test fit.
Not every one has access to equipment like this but it's still beneficial to all that ever plan to use parts that don't fit. There is a fine line between "modifying" and "hacking" it to work.
Don't be a hack. the previous owner of these injectors was informed that they were modified to fit but unfortunately he was mis-informed. Not his fault, but his car may have potentially been a very fast ticking time bomb.
Discussion Starter #445
Nope, My tuner uses the same identical injectors on his daily driven 900whp Evo, Chris Hill uses the same injectors on his DD capable 1G, and a few other reputable folks have chosen this route aswell. I've seen how these perform, I've got not qualms with them.
These are not the natural gas injectors then. Trevor ran those and had huge undrivable issues when they got hot.
Discussion Starter #448
They are indeed Compressed Natural Gas injectors. I have the brown top 0 280 150 837 injectors from an LPG/CNG equipped Crown victoria.
Ford Crown Victoria 4.6L CNG injectors
Ford part# F5TE-B5A FJ231
XL3E-C5A
Chrylser 53030518
Bosch Part#
0 280 150 846
0 280 150 837
0 280 150 839
0 280 150 842
Motorcraft #CM4980 (4803)
Accel 74160
FAST
3016000,
3016004,
3016006,
3016008
Marren 05160
GB REMANUFACTURING Part # 82211133
AIRTEX Part # 4G1256
STANDARD MOTOR PRODUCTS Part # FJ231
Bosch
0280150842-1580cc -Indy Blue tops
## unusual 4.5 ohms
( 14mm top, 16mm bottom )
apparently also marketed as -
* Accel 74160
* FAST 3016000
* Marren 05160
* Marren 051600PI ( 11mm rail fit )
US Ford motorsport fit part
Bosch
0280150846 - 1650 cc -white tops
## unusual 4.5 ohms
is reputedly similar as the earlier blue
[ but alcohol, CNG and LPG vapour compatible ]
( some tests rate them as only 1300 cc )
the blue is a ford USA motorsport item, hence the indy term
the white is a specialised alcohol injector, with heavy pintle , a little slower than the rest
Ford PN:
Ford XL3E-C9A / Ford XL3Z-9F593A
motorcraft - MICM4980
US ford CNG fit part
Bosch
0280150839-1600cc -Aqua tops
## unusual 4.5 ohms
[ alcohol, CNG and LPG vapour compatible ]
US Ford CNG fit part
Bosch
0280150837-1580cc-Brown tops
## unusual 4.5 ohms
US Chrysler CNG fit part
Discussion Starter #449
I dont have the part numbers to verify what injector trevor used but I can verify what I have.
SOHC you in the FACE
Interested to see how they compare. I didn't know Chris was running CNG injectors, I only ever remembered 160# ish.
Pictures of the Mivec fuel rail? Not sure why it was ditched.
Discussion Starter #451
Updates! The build isn't dead yet fellas, I started a new job and it's been keeping me from working on the car. 11 hour shifts suck.
Lawn Ornament Since '08
I used to work 60 hours a week. I bought a DSM and a good 3g's worth or parts. I wish I could go back to that. No life, no drama, no problems.
Same, Average week of work is 60 hours, but I get my weekends off.. if I do have to work a weekend saturday is OT all day, anything over 8 hours saturday is Double Time, and all day sunday is DT.
Also
No kids
GF has her own money and plenty of it
my living expenses resemble someone who makes min wage.
I could work a mere 20 hours a week and still make all my bills every month and have playing around money.
Thank god for the petroleum industry, and never having to pay for gas.
YOUS TROOOLLLLLIN'!
Also
No kids
cool.
OP - what's next on the list?
Escaped
Also
No kids
