Anyone else find that they had to be much more accurate with their feet after installing aftermarket pedals? How quickly did you get used to it? I got the Razo CF pedals today to help me with my heel-toe downshifting (slightly larger than stock, and shaped well for heel-toeing). The only problem is that since they are closer together, and I have big feet, I occasionally bump the gas when I brake, because I'm used to more clearance in between pedals...... I guess I'm just worried about how long it will take to build muscle memory for the exaggerated movement neccessary to clear the gas for hard braking.... in case of emergency when reflex takes over....... How long did it take for others to adjust?
