1 - 6 of 6 Posts
Senior Member
Does anyone have a good aftermarket clutch that they would recomend for a non-turbo, or is the stock clutch the best to go with?
Thanks,
Player--'92 3000GT SL
Unless you have a lot of mods on your car and are putting out a ton of ponies, I'd say stick with the stock clutch. The trannies are delicate even in the non turbos, and an aftermarket clutch will only help you ruin it faster. I had a centerforce dual friction in my Stealth R/T NA and after about 5 months my tranny died. Not saying it's totally the clutches fault, but I'm sure the extra grabbing power didn't help much! I had a stock setup put in after the rebuild and the car is like new. Hope this helps
Scott
'95 Stealth R/T
Senior Member
Discussion Starter · #5 ·
Where do I find out more about this Exedy clutch?
Player
1 - 6 of 6 Posts
