91 Vr4. Stock TPS and Coolant Sensor and they datalog fine in ChromeEcU+Evoscan then I swapped over to AEM Series 2
While trying to dial in hot idle, I noticed the TPS reading is very jumpy when my foot is off the pedal (osculates quickly between 2% to 4%). Same type of quick oscillation with my coolant temp sensor voltages when the car was warmed up.
I swapped back to ChromeEcU+Evoscan and everything seems stable
Are jumpy stock sensor readings normal to see with AEM series 2?
